Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (TexasFarmTruck, UtahYork, crenwelge, Mike1933, tclederman), 215 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
I located a 1967 283ci engine for my 67 truck w/ granny 4-spd. The truck is now equipped with a 1969 307 ci engine. Will the flywheel now bolted to the 307 work for the 283? I assume yes but would like to confirm.
Asking a parts person from Advance or Auto Zone just does not work well on old stuff
Riding in the Passing Lane
Yes. It will fit & work fine.
1972 Chevy c10 Cheyenne Super
Only flywheel you really need to worry about is if you go to the small block 400cid. The 400 is externally balanced and the rest of the SBC's are internally balanced. The small block 400 flywheels can not be interchanged with any other small block chevy.
