dbone,
I think the block casting number that people are referring to above is near the upper right side of the starter (it is a raised number/code).
The engine serial number that you have provided is the number/code that is pressed into the block just behind the distributor.
I do not know if this is at all correct, but my ID numbers book decodes your number/code as follows:
BD837091
BD = Interim-CK series 1/2 ton truck 216 engine (Interim CK series means that it could be any post WWII Chevrolet 1/2 ton truck engine that was produced from 1 September 1945 until the post-war models/engines were produced)
837091 = Production number. This seems like a large number, so do not trust my decoding.
BDA at the beginning
might would indicate an Interim-CK Detroit-built 216 engine; and, then 37091 would be a more reasonable production number.
Check the block casting number (post it here, if you want opinions about it).
Tim
[this question was also posted in
General Truck Talk]
