| | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 24 | has any one used the 47-49 wiring harness from brothers? I plan to stay 6 volt and use the original generator. but i also want to have turn signals...I guess what i am asking is if you have used brother's wiring harness does it come complete with ends and connectors? has anyone run into any problems with this harness? will i have to make any changes to the harness? just like someones opinion on this harness before i buy it...thanks, sam | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you're staying 6 volt you'll need a heavier harness than one made for 12 volt applications. There are a few vendors selling OEM appearing harnesses but they aren't cheap. I used the harness from YNZ on my 38 and I'm quite pleased with it.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Classic Parts is one of several vendors that sell a wiring harness with color-coded wires of the correct length and with terminated ends ($150 - matches the original wiring and circuits). Call them to see if they include wiring for an after-market turn-signal assembly (they did with my 54/55 wiring harness, but an RPO turn-signal assembly was available in those years). The wires in this assembly are plastic (PVC) coated. As state above, the original wires were lacquer-coated braided cloth/thread covered wires (and, a reproduction assembly costs over $600). | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | I have Rebel Wire....link on the 'Bolt vendor area...10% discount too. Not sure if they do 6 volt...you will have to check on that aspect. | | | | | Joined: Nov 2008 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 24 | thanks for the input. i'll check out the classic trucks and rebel wire too, thanks again, sam. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I used classic's on my truck and it worked out great, pretty good instructions included with the set. I would ask about that if you go sompleace else, clear detailed instructions make the job a whole lot easier, classic numbers each wire which then matches the key. | | |
