| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 35 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 35 | I have a 53 chevy 3100 and i have installed the ezwiring harness. i have a wire under the dash for a backup light switch but i am not sure where this switch mounts or where i can get it. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | There is a circular bracket that holds the switch to the column under the dash. There is another actuator bracket that mounts to the shifter shaft. They normally were used on Cameo's that have BU lights in the taillight assy. I have not seen a reproduction. I have one and can send you a picture, send me an email. Fred
| | | | | Joined: Oct 2009 Posts: 35 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 35 | yea that would be great. so these were not originally in the truck? is this just something you have made work. pics appeciated [email protected] | | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | you can make a bracket for the shifter and use a stop light switch. | | |
