1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 116 | Concerning the wheels on the 1.5 tons and 2 ton trucks...Has anyone ever dismounted these wheels with just prybars and such? These aren't the "widowmakers" made by poor ole Firestone. I read the wheel info in tech-tips and its great, but it doesn't tell a farmer how to do it himself, and I suspect that's why these old grain trucks had the kind of wheels they had...so the farmer (you and me) could change a tire or tube right in the field. I'd like to take mine aprt for sandblasting and such and to see if they are still sound inside. Any help is appreciated. I'm assuming that you let the air out of the tube...remove the valve stem...and pry the "snap-ring" off and then everything's free to come apart???Thanks, Jim | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Chetman, in most cases you want to loosen the tire bead, and push it towards the center of the wheel, this can be a very hard job. It's amazing how rubber can weld to steel, especially if given half a century for the process to complete itself. Once the bead is loosened you can push the outer portion of the wheel towards the center of the wheel, to allow the lock ring to be pried out of its groove [depending on the make and design of the wheel]. There are heavy hammers where one side of the head has a large flattened area to assist in breaking the bead, this is very hard work, be careful and wear safety glasses and steel toed boots, good luck. | | | | | Joined: Aug 2008 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 116 | Shop Shark, Thanks very much for the info. I hadn't considered pushing the tire inwards towards the other side of the rim, but I can see how that would really free up the locking ring. I would imagine like every thing else on these old bolts, that some time spent soaking in well-placed penetrating oil would go a long, long way to making the job easier. Thanks again! Jim | | | | | Joined: Sep 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 99 | The other option would be to cut the old tire off if it is finished anyways. A combination of hacksaw, sawzall and cutoff wheel should make short work of the old tire. Then you can have your way with the rim. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | There should be at least one oldtime commercial tire shop in your area. Spend a little time getting acquainted with the oldest guy in the place, and I'll bet he shares a few secrets with you about how to go about breaking down a multi-piece rim safely and efficiently. There are a lot of tricks of the trade involved! Jerry
| | | | | Joined: Mar 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 46 | My grandfather would drive another truck or tractor up on the tire, not touching the wheel, to pop the bead loose.
I've seen others use a bumper jack to break the bead. | | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | I've cut old tires off and I've remounted two tires on my 2-piece rims. It was a chore and it took two of us with prybars, a 20-lb maul and what not. After the second one, we noticed the tube was in backwards (valve pointed the wrong way) ... That's when I said "enough of that" and found a tire shop to do it for $15 a tire. We have a truck tire place here in our small town. The owner is in his 30's and no stranger to multi-piece rims. In fact all of the guys in the truck club here get their tires done there. Any place that does truck tires or ag tires should know how to deal with multi-piece rims. And they don't even have to be old guys to know what they're doing. Funny thing, speaking of old guys, I once tried the old timer in town (in his 60's) -- he took one look at my 2-piece rims (NOT the Firestone RH-5's) and essentially told me to get lost. The 30-year old guy took them in and did all six while I stood there and watched. All the home tricks and old guy techniques still can't compare to the ease of giving a guy $15/wheel to do it  John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I'm one of those late 60's geezers who doesn't really care to do himself any more. I have taught a lot of young guys how to do it over the past 45 years, but I just don't have the energy any more. I don't have anyone at my shop that really knows how to change tube required tires, but when they are on my payroll, they do it with my supervision. We don't have a tire shop around that will tackle them any more. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Unfortunately, I'm THAT guy in this town John, and I won't do it for $15 anymore either, haha Scott | | | | | Joined: Mar 2008 Posts: 33 Apprentice | | Apprentice Joined: Mar 2008 Posts: 33 | I do them myself. I use a homade "slide hammer" bead whacker and a big "Jackall" jack under the bumper of my truck to pop the beads. The rest is just patience and carefull cleaning and inspection of the rim,flange and lockring. Then put it all back together with new tire and slide it under the truck to act as a cage and reinflate it with a long whip hose so your well out of the way and safe. Comon sence and a bit of advice from an oldtimer goes a long way here. I now can pass on a lost skill to others. Seems modern tire shops have evryone scared of these simple "feild serviceable" rims.
I suffer from ADAD (Advance Design Acquisition Disorder)
