1 members (moparguy), 39 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#640981 04/26/2010 3:41 PM
blush I need some help choosing the BEST and EASIEST front clip on my 52 in order to have good suspension disc brakes. I plan to also put a modern rear end under the truck. any help would be appreciated. It looks like i need to provide more info. I have several options I am thinking about, but the main use of the truck will be to cruise and drive often around town. I have a 69 350/350 SBC built, a 72 402 BBC, a 56 291 Desoto Hemi built and transmission options turbo 350,400 & BW 4spd.
"BEST and EASIEST front clip" is a matter of opinion.
Welcome to Stovebolt. You've opened a can of worms on your first post.
Here's my opinion. Many more will follow.
I am extremely happy with power disc brakes on a stock straight axle truck. I say the best and easiest is NO CLIPS. It's a truck. It should have truck suspension.
Y
Y Offline
I'd suggest you do a search on this topic and check out the tech tips! This is one of the most popular topics.
52flattire, firstly welcome.
What will be your main use for your truck?
Show,daily driver,workhorse etc.
There are literally hundreds of permutations you can go for,I agree with Cletis though, keep the original frame,and go from there.
I've never been a fan of 'cutting and shutting' chassis.
If you really have your heart set on changing out the original set-up,one of 'our own', Scott Danforth does a really nice IFS kit that utilises Chevy parts.
Hope this helps
More pix on Flickr.
