| | | Forums66 Topics128,198 Posts1,057,269 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 27 New Guy | | New Guy Joined: Nov 2006 Posts: 27 | I am confused at the ratings for GMC's. I think a 350 is a 1 and 1/2ton truck but on the 450's I have seen them rating from 2 ton to 3 ton. Is a ss # 453-30 Z2786 with gross wt at 19,500 a 2 ton or 3 ton. Spanky has a COE 450 which is a 3 ton?
It has a master cylinder that has a Wagner FE 3419. I have seen in some catalogues a new one for a 2 ton and larger. They also are called "Utility" truck It is a large MC compared to a pickup. What does the "Utility" designation mean? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | With gross wt. at 19,500 it would be five ton or maybe six ton. subtract the weight of the vehicle and divide by 2000. Is that number on the data plate from the factory or just painted on the side of the truck somewhere? | | | | | Joined: Nov 2006 Posts: 27 New Guy | | New Guy Joined: Nov 2006 Posts: 27 | It is the original number on the drivers side post. It is a 1954 I know a 100 is a half ton 150 a 3/4 ton 250 a one ton | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | I have been in the trucking business since 1963 and I am still confused. GMC called a 350 a 2 ton and a 450 a 3 ton. The trucks I run today have a gross vehicle weight of 52,000 and a gross combination weight of 80,000 and an empty weight of 14,000, but they are registered as 5 ton. When you get into larger trucks. the tonnage is just a nominal rating that means nothing. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | I have been in the trucking business since 1963 and I am still confused. GMC called a 350 a 2 ton and a 450 a 3 ton. The trucks I run today have a gross vehicle weight of 52,000 and a gross combination weight of 80,000 and an empty weight of 14,000, but they are registered as 5 ton. When you get into larger trucks. the tonnage is just a nominal rating that means nothing. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | It is the original number on the drivers side post. It is a 1954 I know a 100 is a half ton 150 a 3/4 ton 250 a one ton 280 is a ton and a quarter. 300 is a ton and a half. 350 is a 2-ton. 450 is a 3-ton. It goes higher and I believe there are models like a 400 that fit in the middle... If you still have the original motor its a 302 judging by the serial number.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2006 Posts: 27 New Guy | | New Guy Joined: Nov 2006 Posts: 27 | Thank you.
It is obvious now that I see the models broken down. My hang up was that I thought the 350 was a ton and a half. | | |
