3 members (TUTS 59, Maybellene, baldeagle), 61 guests, and 2 robots.
Topics128,060
Posts1,055,835
#640795 04/25/2010 8:15 PM
Should the turn signal switch center it self without the stalk. Mine stalk has to be exactly centered for the brake lights to work. The post fits in the switch as it should. Thanks, Bob Giles
not quite clear just what you're saying Bob, except the signal units do have some springs and detents in them that should positively locate the 'off' position, and if the switch isn't moving correctly it could affect the brake lights
you should pull the wheel and take a look - see if the springs and pawls shown here are all intact, the coil springs are important to proper operation
Thanks for the advice.
The mechanical part seems to be working fine. The electrical part doesn't feel like it has any detents. If its not exactly centered, no brake lights on one side or the other. I think this "new" switch is faulty.
the switch itself has no real detents it's just a sliding set of contacts, the mechanics in the cup is what positions it, at 'center' the mechanical parts should 'detent' and the lever shouldn't be able to be either side of that to confuse the switch, in the center/off position, there should be no play, if there is something is worn
"If its not exactly centered, no brake lights on one side or the other. I think this "new" switch is faulty."
If you are talking about a factory type switch that is how it is supposed to work. When pushed down you should get a brake light on the right and a flashing light on the left. And the opposite when the lever is pushed up.
My old one did this. It did not mechanically center itself after turning. Not being centered would cause one or the other brake lights to not work. I installed some indicator lights under the dash wired to the brake lights so I could tell when the switch was centerd correctly. Replaced some of the old mechanical switch parts, cleaned and lubed the rest and everythings good now.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Life is good, replaced the switch and problem solved. Got a price from Shee-mar and Jim Carter. Both switches were made off shore with JC being half.
