8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, 1 invisible),
103
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Anyone try and adapt their 235 or 261 to a screw on oil filter (conventional set used on late models). If so, do you have a pic to share of how it turned out?
Hank | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Presumably you are looking for a screw-on filter-assembly used on a 235/261 by-pass filter block? I have used two different plumbing styles and locations for a screw-on filter-head used on full-flow 1958-63 261 blocks.
If you want photos posted, please let me know.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Here’s a few variations that maintain the bypass system. Search and you’ll find many clever methods.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are going to put a spin-on filter on a by-pass block, it has been suggested to place a "restrictor" washer in the system. Maybe someone who has done this will comment?
| | | | | Joined: Feb 2004 Posts: 29,776 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,776 | I use a Holley carburetor main jet in the return line fitting. Something about 1/16" (.060") in diameter will restrict the flow enough to prevent a serious drop in oil pressure. Be aware that a full-flow filter has such large openings in the filter media that all it strains out are the big chunks, so you won't get very effective filtering. It makes people feel better, though, thinking they're protecting their engine. If you can find a spin-on filter intended for hydraulic fluid, or something similar that screws onto the remote filter adapter and filters down to 2 or 3 microns, use that type of filter instead of the more commonly available full-flow spin-ons. The cost will be more than the canister filter the factory specified, but it's a little more convenient to use a self-contained filter instead of replacing a cartridge. Jerry
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | What he said. An Amsoil bypass filter head (shown in my example) has a 1/16” restrictor which could be added to the average filter mount found at a FLAPS by inserting an NPT pipe plug and drilling a metering hole in it as well as Jerry’s method. An Amsoil bypass filter has an efficiency rating of 98.7% at 2 microns and will remove soot as well as the very small particles that cause the most engine wear which I believe to result in much cleaner oil than any full flow conversion would accomplish. http://www.amsoil.com/storefront/bf.aspx
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Jerry, Curt & Tim....I appreciate the valuable info and links. You guys are awesome!
Hank | | | | | Joined: Feb 2004 Posts: 29,776 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,776 | If you want 10 times the protection of an Amsoil filter, get a Frantz toilet paper filter- - - - -they strain it down to 2/10 micron! Jerry
| | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | I'll keep that in mind Jerry  | | |
