1 members (Samantha), 45 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
I
I Offline
Has anyone used this product on an oak bed? The local wood experts are saying it is great.
Product Description
Here's a tough, clear finish that will shrug off sun, rain and wind and look good doing it. With UV absorbers to reduce sun damage, and mildewcides to keep mold and fungi at bay, General Finishes' Exterior 450 will reduce fading and greatly lengthen the life of any exterior wood. A water-based clear acrylic finish, it's ready to sand in only 1 hour, is low-odor and is easy to clean up. It's very flexible, so it resists the cracking and peeling caused by hot summers and cold winters.
Cleanup: Warm, soapy water.
Dry Time: Ready to sand in 1 hour under ideal conditions (70F, 70% humidity). Cooler temperatures and higher humidity will prolong drying time.
Thinning: If necessary, thin with 10-20% water.
Application: use a foam brush, paint pad applicator or spray gun.
Can be sprayed through compressed air, HVLP, airless or C.A.S. units.
Oil-based stains must be completey dry before using a water-based top coat. Wait a minimum of 48 hours before applying GF Exterior 450.
This product is water based So I like the clean up. My bed will not be exposted to weather on a regular bases. your thoughts. THX
Before doing anything you may want to click on Mar-K's link here on the bolt and read up on their test of finishes for our bed wood. Its interesting and helps you make a more informed decision for your particular needs.
It's probably as good as any exterior polly finish. Problem with urethane topcoats is that they just lay on top of the base they are applied to and when moisture gets under them the begin to lift.
DG
Denny G
Sandwich, IL
