1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#640416 04/24/2010 6:34 AM
Does anyone know if you car interchange hyd. lifters for solid ones. 1956 235cid chevrolet engine. I think I would like the solid lifters better. Thanks, Steven
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Red 49 Truck #640435 04/24/2010 12:50 PM
I'd stay with the hyd. less screwing around they will stay in adjustment and you're cam is for hyd. lifters no HP. gain unless You're building a race engine there is no advantage.
Pete
Pete52 #640488 04/24/2010 5:48 PM
As I understand it you also need to change the cam to a solid lifter type. The lift profiles are different.
Still, to the original question, I'd like to know too if there is any reason you can't run solids in a block originally equiupped with hydraulics, i.e. are they the same diameter, to you need different pushrods? I've heard that unless you can find a set of NOS lifters that your better off with solids.
Red 49 Truck #640498 04/24/2010 6:32 PM
H Online: Content
No problem running solid lifters in a block with the oil gallery for hydraulics, but you MUST run a solid lifter camshaft, also. The valve clearance would have to be run at .004" or so to run solids on a hydraulic shaft, and adjusted about once a week otherwise. There's a major difference in the lobe shape on a solid lifter shaft.
Hotrod Lincoln #640515 04/24/2010 9:06 PM
So the solid lifters are the same diameter as the hydraulics?
waldo53 #640520 04/24/2010 9:25 PM
H Online: Content
I believe so. After a certain year, all the blocks were bored for the oil gallery, whether or not the hydraulic lifters were used. It would have made no sense at all from a manufacturing standpoint to have two different lifter bore sizes.
Hotrod Lincoln #640532 04/24/2010 11:11 PM
Riding in the Passing Lane
I believe the pushrod length is different.
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #640543 04/25/2010 12:08 AM
when i had my 59 built the engine guy gave me hydraulic lifters. i told him i wanted solids. he said he'd have to change the cam to a solid lift cam. after he gave me the engine back with the correct cam he gave me the lifters and they were solids but the milk can type. the lifters are the same od but the hydraulics and the solid with the annual are shorter thus the longer rods. there are two rod lengths 10 9/16th and 11 1/4qtr.
51 ashton #640584 04/25/2010 2:41 AM
you need longer pushrods to run hydro. the solid lifters are taller so you need to make up the height.
monkey wrench #640623 04/25/2010 3:31 AM
Stay with the hyd. lifters, less adjustment to do.
Tommy
59 apache 1/2t
261 short stepside
