1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Does anyone know if you car interchange hyd. lifters for solid ones. 1956 235cid chevrolet engine. I think I would like the solid lifters better. Thanks, Steven | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I'd stay with the hyd. less screwing around they will stay in adjustment and you're cam is for hyd. lifters no HP. gain unless You're building a race engine there is no advantage.
Pete | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | As I understand it you also need to change the cam to a solid lifter type. The lift profiles are different.
Still, to the original question, I'd like to know too if there is any reason you can't run solids in a block originally equiupped with hydraulics, i.e. are they the same diameter, to you need different pushrods? I've heard that unless you can find a set of NOS lifters that your better off with solids.
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | No problem running solid lifters in a block with the oil gallery for hydraulics, but you MUST run a solid lifter camshaft, also. The valve clearance would have to be run at .004" or so to run solids on a hydraulic shaft, and adjusted about once a week otherwise. There's a major difference in the lobe shape on a solid lifter shaft. Jerry
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | So the solid lifters are the same diameter as the hydraulics? | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | I believe so. After a certain year, all the blocks were bored for the oil gallery, whether or not the hydraulic lifters were used. It would have made no sense at all from a manufacturing standpoint to have two different lifter bore sizes. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I believe the pushrod length is different. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | when i had my 59 built the engine guy gave me hydraulic lifters. i told him i wanted solids. he said he'd have to change the cam to a solid lift cam. after he gave me the engine back with the correct cam he gave me the lifters and they were solids but the milk can type. the lifters are the same od but the hydraulics and the solid with the annual are shorter thus the longer rods. there are two rod lengths 10 9/16th and 11 1/4qtr.
| | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | you need longer pushrods to run hydro. the solid lifters are taller so you need to make up the height. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Stay with the hyd. lifters, less adjustment to do.
Tommy 59 apache 1/2t 261 short stepside | | |
