1 members (Rusty Heaps),
114
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | I have a 85 dodge subframe in my 59 chevy and a GM power steering pump on a 350. I've been told i'll need to reduce the pump pressure. How is this done? Is there danger of blowing out seals? Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | I have removed it from the Engine & Driveline section. Sorry | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The control valve kit is available from most speed shops and consists of small rings and a holding device to dissasemble & reassemble the valve. The last one I got was produced by Bill's Hot Rod. Remove the 1" fitting that backs up the hose connection on the lower rear of the pump. Inside you will find a control valve and a spring. The instructions list the different pressures as regulated by the number of rings installed. I'm not sure what pressure is required for a Dodge. Ford and Toyota operate on about 900psi. The factory GM pump produces about 1300psi. You could cause some problems with too much pressure. I know on Mustang II racks they tend to react too fast and are kind of squirrely to drive. Fred
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I got my valve from Jegs.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | There are a couple of ways to reduce pressure as per previous posts. Least expensive is shim kit as described by rfs56trk. Simple install - experiment with number of shims until steering feels right. You can also use an adjustable valve per We b Old's suggestion. More $$ / easier adjustment. Most speed shops have one or both in stock. | | |
