3 members (Bill Hanlon, 2-Ton, Millenimech), 65 guests, and 1 robot.
Topics128,042
Posts1,055,519
Members48,424
#639188 04/20/2010 1:51 AM
I have a 85 dodge subframe in my 59 chevy and a GM power steering pump on a 350. I've been told i'll need to reduce the pump pressure. How is this done? Is there danger of blowing out seals? Thanks
I have removed it from the Engine & Driveline section. Sorry
The control valve kit is available from most speed shops and consists of small rings and a holding device to dissasemble & reassemble the valve. The last one I got was produced by Bill's Hot Rod.
Remove the 1" fitting that backs up the hose connection on the lower rear of the pump. Inside you will find a control valve and a spring. The instructions list the different pressures as regulated by the number of rings installed. I'm not sure what pressure is required for a Dodge. Ford and Toyota operate on about 900psi. The factory GM pump produces about 1300psi. You could cause some problems with too much pressure. I know on Mustang II racks they tend to react too fast and are kind of squirrely to drive.
Fred
rfs56trk #639603 04/21/2010 2:49 PM
I got my valve from Jegs.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
WE b OLD #639919 04/22/2010 5:30 PM
There are a couple of ways to reduce pressure as per previous posts. Least expensive is shim kit as described by rfs56trk. Simple install - experiment with number of shims until steering feels right. You can also use an adjustable valve per We b Old's suggestion. More $$ / easier adjustment. Most speed shops have one or both in stock.
1940 Chevy KC 1/2-Ton
