| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | The front wheel seals have one completely smooth side, and the other side with the visible joint where the two pieces are locked together. Does it matter which side goes to the inside of the hub (or outside)?? This is on a '39 pickup.
Gary | | | | | Joined: Sep 2005 Posts: 50 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 50 | outside / side that goes onto the spindle should be the smooth side | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | 52,
I appreciate it. The current seals are in backwards. They were installed maybe 25 years ago. I will have to rag the mechanic...me.
Never too old to learn.
Gary | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it's the old fabric type seal it doesn't really mater. If it's a rubber type seal the lip faces in towards the grease. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | Wrenchbender,
I think it's the newer rubber kind. I assume you mean the rubber lip. I will check it tonight...or tomorrow morning. Long day for an old fart, and supper is soon...I hope.
Gary | | |
