3 members (Materman, blanch53, 1 invisible),
125
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | My truck manuals seem to be more for the younger trucks than for my 48. I am wondering if there is a good diagram for the 'guts' that are inside my 48 doors.
I think there are some braces missing. And where would I get the stuff that is missing? When I figure out what should be there I will put an add in the parts are wanted forum.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2010 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 119 | See if the assembly manual for your truck is at the oldcarmanual project. Probably buy a door(s) and get them that way or check some of the vendors as well. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Best source for door view is the Master parts Catalog and the 47-50 specific cab manual (reproduced). | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks guys. My assembly manual did not show this view. I will look for the masters parts catalog and/or specific cab manual.
Thanks again. I appreciate the help
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | What I found was the front window guide had rusted or broken. While in Oklahoma last weekend (HOT) Justhorsenaround sold me a door with this guide in it. Now, I need to figure out how to get this into the door.
Any advice or experiences with this surgery?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Brad, what is the “47-49 cab specific manual”? Not sure I’ve ever seen one of those, and here I thought I had one of every thing in print for the 1950 AD truck. Denny G
Denny G Sandwich, IL
| | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | The front window guide in my '49 GMC is also rusted/gone. Haha, just wasn't there. Now I know why the window doesn't go up. I've been looking around here for a door, and also wondering how to get that piece back in. Might it be easier to just swap doors?
Anybody have a fix? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Denny,
There is a small glovebox size manual for 47-51 Cabs that illustrates how to shim, change weatherstrip, glass etc. Look in the Jim Carter Catalog Item #LI540 They are $6-7$ as I recall. It is a handy little book with lots of pictures and tips.
Brad
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | In regards to your 49 door that piece is spot welded into place your best bet is a replacement door. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | The door I bought from Justhorsenaround has bullet holes in it and a dent.
I agree with you Brad. I am not sure if I could position the guide in the right place for spot welding and make the window work.
| | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | Thanks guys. The door isn't very rusty at all, it's a shame to have to swap it. There's a fella around here with a few parts trucks, I'll go by and see if I can't get a good door cheap.
