4 members (J Lucas, TexasA&M48Truck, Otto Skorzeny, Ed Atkisson), 52 guests, and 3 robots.
Topics128,021
Posts1,055,373
Members48,420
#638707 04/18/2010 11:53 AM
hi just aquired a 50 1/2ton front axle assmeble i mesured it and all and everything appears both visualy and appears to be exactly the same as far as axle perchs even how wide, are there going to be difference in the spindle or other things i can't yet see, see i have a disk brake conversion for the 39 i picked up last year "havn't used it yet" and i am hoping i can use it on the 50 front axle if anyone has info on this let me know thanks
1937 1/2 ton
Should work, just bigger kingpins in the 50.
DB , I have a '54 front axle in my '40. Its good.
I'm running a 41-54 1st Series axle under my 37. Everything works great! Just bolted it in!
You might run into a bearing inner diameter problem. My truck has a early 50's axle and the '37 brake kit I bought wouldn't fit. Something about the inner bearing wasn't right. I ordered a newer kit and it went right on. Joe
