7 members (dgrinnan, Scott '48 2ton, Wayne67vert, Jon G, NorthCoast3800, Gray_Ghost, Peggy M),
103
Mod | | | Forums66 Topics128,163 Posts1,056,962 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | Does anyone know off hand if the single acting linkage will fit the double acting delco's?
The reason why I ask is that the linkages are in pretty bad shape on my delco's and need replacing/refurbishment.
The action of the linkage is the same, just not sure if the width of the linkage heads are correct.
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | There's only one listed that I know of so I'd think they are the same. Chevs shows a different link bushing for the double action shock but the link itself appears to be the same.
| | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | The bushing they list is for the yoke type linkage, which is what all double acting shocks I have seen are equipped with, which probably answers my question. It has a rubber busing at the top, and the bottom is a threaded rod, similar to a modern tube shock.
