4 members (66flea, cmayna, Shaffer's1950, Wally / Montana), 106 guests, and 1 robot.
Topics128,154
Posts1,056,838
Members48,456
Y
Y Offline
Does anyone know off hand if the single acting linkage will fit the double acting delco's?
The reason why I ask is that the linkages are in pretty bad shape on my delco's and need replacing/refurbishment.
The action of the linkage is the same, just not sure if the width of the linkage heads are correct.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
Ex Hall Monitor
Ex Hall Monitor
There's only one listed that I know of so I'd think they are the same. Chevs shows a different link bushing for the double action shock but the link itself appears to be the same.
Y
Y Offline
The bushing they list is for the yoke type linkage, which is what all double acting shocks I have seen are equipped with, which probably answers my question. It has a rubber busing at the top, and the bottom is a threaded rod, similar to a modern tube shock.
