| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | Can anyone tell me where I can find a brake parts schematic for a 95 chevy 6 lug rear. I swapped this rear into my 50' but it had none of the brake hardware attatched. Thank you for any suggestions.
John 50' chevy 3100 shortbed
| | | | | Joined: Mar 2010 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 76 | I believe the spring and pin setup is the same as the rest of chevy. I think they changed them in 1996. So, if you've done chvy drums before you should be good to go. But i could be wrong. Who knows with GM. I searched and couldnt find a pic, diagram, or schematic. | | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | Thanks for checking 561ton, I could'nt find anything online either as far as parts diagram. I know some parts are missing so i'll check brake shop tomorrow to see if they have exploded view and part #'s
| | | | | Joined: Mar 2010 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 76 | It should be the old style. Like the ones from th60's on up. Good luck in your search! If I do run across anything I'll let you know. | | |
