Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (farmallb, Shade Baby, baldeagle, klhansen, 50Chevy3100), 51 guests, and 1 robot.
Topics128,005
Posts1,055,261
Members48,418
#638796 04/18/2010 6:23 PM
Can anyone tell me where I can find a brake parts schematic for a 95 chevy 6 lug rear. I swapped this rear into my 50' but it had none of the brake hardware attatched. Thank you for any suggestions.
50' chevy 3100 shortbed
jhannigan #638854 04/18/2010 11:00 PM
I believe the spring and pin setup is the same as the rest of chevy. I think they changed them in 1996. So, if you've done chvy drums before you should be good to go. But i could be wrong. Who knows with GM. I searched and couldnt find a pic, diagram, or schematic.
561tonpanel #638868 04/19/2010 12:35 AM
Thanks for checking 561ton, I could'nt find anything online either as far as parts diagram. I know some parts are missing so i'll check brake shop tomorrow to see if they have exploded view and part #'s
jhannigan #638875 04/19/2010 1:44 AM
It should be the old style. Like the ones from th60's on up. Good luck in your search! If I do run across anything I'll let you know.
