4 members (k2handyman, moparguy, dt235sd, Hotrod Lincoln), 71 guests, and 1 robot.
Topics128,049
Posts1,055,678
#638430 04/17/2010 5:53 AM
i did a search and couldnt find anything on this. i have a 66 C-30, and this is the first pre-73 truck i have owned. i keep hearing a whirring sound when im going in reverse when i let off the clutch. just wondering if this is normal or a sign of things to come. also i cant figure out how to check/fill the tranny fluid. any help would be greatly appreciated! thanks guys.
66' Chevy C-30 Rat
More than likely it is the clutch release bearing also known as the throw-out bearing. You should be hearing it to some degree in all gears. It is likely worn out. You should probably replace the clutch also since you have to remove the transmission to get to it. All 3 speed and 4 speed transmissions have a fill plug on the right side of the trans case.
Fred
Riding in the Passing Lane
These old trans. did naturally make a little noise in reverse. It will have some whine in all the gears except high but if its too much it could have a brg. in the trans that is scored. There is a pipe plug on the side of the trans. You fill it to the lvel of the plug. There is a plug on the bottom to drain it which is a good idea. Sometimes the old grease has been in there for many years.
1972 Chevy c10 Cheyenne Super
thanks alot guys! im planning to replace the clutch in a couple weeks because its really a fight to get it pushed in. i havent noticed that noise in any other gear, but ill start paying more attention!
66' Chevy C-30 Rat
H Online: Content
Reverse has straight-cut gears which naturally make more noise than the forward gears, which are cut on an angle, and share the load of pulling between three teeth, not one at a time. If the noise happens just as you're letting the pedal out to engage the clutch, the throwout bearing is at least part of the problem.
nope; its only in reverse. . . .and it sounds horrid. definitely going to have to do something.
66' Chevy C-30 Rat
