2 members (baldeagle, Forty9),
60
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 | I am restoring a 1953 3100 PU with a 235ci. The throttle rod which is the rod from the gas pedal to the carberator is not usable. Does anyone know where I can get a new one? Can't seem to find one on line. Thanks.
1953 3100 Chevy 5 window 1971 Chevelle SS
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | They used basically the same throttle rod from the late 30's to the 50's. The last one I needed I picked up at a wrecking yard.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | You can make one by mounting one of these (SC107 -1/4” x 1/4”) on the carb, another on the bellcrank, and join them with a pc. of 1/4” rod cut to length and threaded a bit. http://www.aetnascrew.com/bjoint3.htmNot original but removes slack effectively.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 |
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | There are two types of these if you are using your original gas pedal yours will have a ball end (1952-1959) the earlier versions (1947-1951) have a slotted end that uses a pin. | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | Jim Carter has used parts. Also, I see linkages on eBay a few times each year. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I have one if you want I can e- mail you a pic PM me your e-mail address
Pete | | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 | Thanks Pete, my email address is [email protected]
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Sent You a E-Mail with pics
Pete | | |
