| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 38 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 38 | Hi.... Rim options... I need some newer rims, and did the research. I would like narrow rims, 6" or less with 6 lugs. I did a nationwide Craigs List search and found a bunch and learned a lot in the process, but need a little more specific information and wonder if anybody else had done this and could save me some time with the information. I found posts that would confirm that Toyota and Mazda rims were 6" wide and 6 lug and fit a Chevy. They even had pictures, but nobody seemed to know what range of years had these, or was it all of them? Ideas? Is there a rim made that is less than 6" and 6 lug? I have time on my side, so I will be looking at swap meets for something in the next few years. I don't care to buy anything new... money IS an issue; isn't it always? | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | My stock rims are 6" wide...had 'em sand blasted & powder coated. My "other" rims are the white "wagon wheel" style, 7" & 8", but I think they had 6" available. Check Wheel Vintiques website...
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Aug 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 33 | I pretty much always run original GM wheels from the mid to late 50's. I have had 15" by 5" and 5-1/2" original wheels on most of my trucks. | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | I picked up some AD wheels a while back, 16x4. Were available in 15" also.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
