2 members (KEVINSKI, 55shaker),
125
Mod | | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 18 New Guy | | New Guy Joined: Apr 2010 Posts: 18 | hello there. new to this forum. i just acquired a '49 chevy truck frame that came with a '54 235 inline 6 w/4speed transmission and drive-train - a 'runner.' i want to swap it over to my '39 Chevy truck to beef up the power but keep the exterior "original." I've got my old 216 and 3 speed out, but need some advice on how this "new" set-up is going to fit and what I'll need to do, etc. (how do i check to see if rear-end/driveline, tranny, front end, etc. will fit?)
thoughts?
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | as an owner of a 39 think your going to hit alot of mounting probs body mounts will be different your running boards and specialy your front radiator mounts and supports it can be done but you can count on alot of fab work
1937 1/2 ton
| | | | | Joined: Apr 2010 Posts: 18 New Guy | | New Guy Joined: Apr 2010 Posts: 18 | thanks Daniel. I'm going to use the '39 frame as my base and the '54 motor uses the same motor mounts and has the short water pump, so i think i'll be good there - more worried about tranny on back!  | | |
