4 members (Hotrod Lincoln, walter74, J Lucas, 3800GUY), 138 guests, and 2 robots.
Topics128,134
Posts1,056,406
Members48,441
#637946 04/15/2010 4:58 PM
Apprentice
Apprentice
hi guys
i am working on a 1950 chevy 3/4 ton and i am wondering has anyone put a tci rear leaf set up in a 3/4 ton? i dont know if i should use the 1947-55 or the 1955-59 set up. also just wondering how much work it will be to install
thanks guys
tony
I'd call them directly and ask. The frames are different behind the cabs, so you may have an alignment issue with the spring hangers.
