5 members (Jon G, baldeagle, Nick in Manitou, TexasJim50, Woogeroo), 66 guests, and 2 robots.
Topics128,014
Posts1,055,332
Members48,419
#637751 04/15/2010 1:23 AM
1 Offline
I am restoring a 1953 3100 PU with a 235ci. The throttle rod which is the rod from the gas pedal to the carberator is not usable. Does anyone know where I can get a new one? Can't seem to find one on line. Thanks.
1953 3100 Chevy 5 window
1971 Chevelle SS
1953Chevy #637800 04/15/2010 3:54 AM
They used basically the same throttle rod from the late 30's to the 50's. The last one I needed I picked up at a wrecking yard.
You can make one by mounting one of these (SC107 -1/4” x 1/4”) on the carb, another on the bellcrank, and join them with a pc. of 1/4” rod cut to length and threaded a bit.
http://www.aetnascrew.com/bjoint3.htm
Not original but removes slack effectively.
You Tube
Curt B. #637894 04/15/2010 2:42 PM
1 Offline
Ok, thanks for the tips
1971 Chevelle SS
1953Chevy #637949 04/15/2010 5:00 PM
There are two types of these if you are using your original gas pedal yours will have a ball end (1952-1959) the earlier versions (1947-1951) have a slotted end that uses a pin.
Brad Allen #637960 04/15/2010 5:59 PM
Jim Carter has used parts. Also, I see linkages on eBay a few times each year.
Brad Allen #637961 04/15/2010 5:59 PM
I have one if you want I can e- mail you a pic PM me your e-mail address
Pete
Pete52 #638139 04/16/2010 5:17 AM
1 Offline
Thanks Pete, my email address is [email protected]
1971 Chevelle SS
1953Chevy #638611 04/18/2010 1:42 AM
Sent You a E-Mail with pics
Pete
