4 members (Gdads51, MickeyP, TUTS 59, Otto Skorzeny), 23 guests, and 5 robots.
Topics128,013
Posts1,055,312
Members48,419
#637616 04/14/2010 3:45 PM
I am restoring a 1949 Chevy p/u truck. I didn't origionally remove the cab but it has been painted and ready to install ont he frame. I bought the Cab to frame installion hardware part # CB250 which contained the two long bolts for the front of the cab nuts and washers and spacers. These I know are for the front of the cab. I also have 8 round rubber spacers with holes in them. can anyone send me a picture or tell me where these go between the frame and cab. It appears that bolts go through these spacers.
OLTrucks
Unregistered
OLTrucks
Unregistered
Sounds like you must have an early 1949 cab they use a center rear mont and two bumpers for the rear on each side. Carter's CB157 has the same pads and bolts for the front but come with two new bumpers for each side of the rear. Might give em a call and see if they will swap em out with you.
Mike
#637661 04/14/2010 8:00 PM
Here is what the cab mounts look like:
First picture mid 49-1955 1st series:
http://community.webshots.com/photo/2379203940102454676qNTFMD
That is where the eight rubber donuts go.
Second/Third Picture is the center mount shackle 1947-Mid 1949
http://good-times.webshots.com/photo/2770506040102454676cTSfPv
http://good-times.webshots.com/photo/2433221960102454676NebfQM
Easiest way to tell is gas tank in cab uses the newer style.
The first photo is the one I have. I replaced the old worn out shackles and Have the two metal plates that go inside the cab to bolt to the shackles. I do not have the 4 spacers with two holes in each spacer. Are you saying that the rubber gromets go in between the shackles and the bottom of the cab. Where do the spacers go on top of the gromets next to the bottom of the cab. you did not show in the photo but the front bolts go through the floor board and through the extension out from the frame.
Bennie
#637740 04/15/2010 12:31 AM
Mike thanks I don't believe that I have early 1949 because I don't see the center rear monuts
thanks
Bennie
Your right, those 8 rubber spacers are for the rear shackle mounts.
When I rebuilt mine I ended up reusing the old rubber, just cleaned up and lightly greased.
Use the search engine here before you mount your cab. There is a certain dimension you need to shoot for when you mount your cab. search....AD cab installation its in the paint and body shop forum
rear mount
cab mount
inside cab
DADS50 #637871 04/15/2010 12:51 PM
The best thing to get for yourself is a assembly manual and a shop or repair manual as your building your truck this way if your in the middle of a project and need to know somthing you can look it up all the dimensions are there
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0102.htm
Pete
PS I linked the info ,frist time
Pete52 #638226 04/16/2010 3:29 PM
Pete
Thanks I looked at the manual you linked and your right I ordered a manual.
Bennie
