1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 5 New Guy | | New Guy Joined: Dec 2008 Posts: 5 | I need the dimentions of the bed mounting blocks. A friend has a 1949 3100 short box and we can't find them. Also how many blocks are there?
Thanks beebee | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | You can order them from Jim Carter probably just about as cheap as you can make them. Link to page 12 of the catalog. | | | | | Joined: Dec 2008 Posts: 5 New Guy | | New Guy Joined: Dec 2008 Posts: 5 | I know that we can get them but my friend wants to make them
beebee | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The after market ones I bought are 2 1/4"x 2 1/4"x 2 1/4"
I dont have originals to measure
youll need 4ea
| | | | | Joined: Dec 2008 Posts: 5 New Guy | | New Guy Joined: Dec 2008 Posts: 5 | That's the diamentions I was looking for.
Thanks beebee | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Factory ones were cut from pine...yellow pine I believe. Prior post is on the money with dimensions and number you will need. Plan to place a new piece of a rubber tire inner tube cut to size between each block and the frame on mine. Not factory spec...just my plan for what it is worth. Hank
| | | | | Joined: Dec 2008 Posts: 5 New Guy | | New Guy Joined: Dec 2008 Posts: 5 | | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Might even be cheaper to buy them, but a lot of the fun of these old trucks to me is what you can make to work/fit on your own with not a lot of expensive shop equipment. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I do believe these old trucks were designed to be rebuilt in a corn field. My son bought an 1974 International Scout II and is planing on restoring it. Trucks keep getting more and more complicated these days.
~Jim
| | | | | Joined: Dec 2008 Posts: 5 New Guy | | New Guy Joined: Dec 2008 Posts: 5 | Hankdogg i agree I like to make things work and I think thats the way it was done with these trucks on the farm.
Thanks for all the info guys I have all that i need for my friend
beebee | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I wouldn't put any rubber between the bed and the frame Hank. You really don't want the bed to move around, putting a soft material in between would allow it to shift. But then again, I wouldn't mount the fenders to the bed sides with welting or anti-squeek either. Some how the engineers at GM had this all figured out 60 years ago.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 |
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Jun 2011 Posts: 17 New Guy | | New Guy Joined: Jun 2011 Posts: 17 | Thanks guys, this is what I need. I know you can buy them cheaply, but I want to make them myself. Our truck project took a hiatus this spring while my 82 year old dad and I took out a huge maple stump by his house. I saved some chunks of it, and already made him a new gearshift knob from it. Just thought it would be fun, and memorable for us, to make these as well. I know he won't be around forever, so I want to build memories like this when possible. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I was reading somewhere on this forum that the wood was 1" (3/4")? I'm wondering if the original board would not have been 7/8" thickness at that time? I can remember 2 x 4s being 1 3/4" x 3 3/4", then they went down to 1 5/8" by 3 5/8" to the present 1 1/2 x 3 1/2". I'm thinking back at the time these trucks were new the 1" boards would have been 7/8" thick. John | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ... I'm thinking back at the time these trucks were new the 1" boards would have been 7/8" thick. John or maybe if they're said to be 1" .... they're 1"? Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Larry,
I made the blocks for my Suburban out of seasoned Maple. I used the bed mounting pads cut to the size used on the panel-body mounts.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | The reason I figured 7/8" was this would allow the board to be groved the same as the rest where it fit under the strips along the bed sides then. So all the strips would be even then. It was noted in a link that the 3/4" boards just fit under the outside strips and were not grooved. John | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | John, the boards on the outside are/were not grooved, but the sheet metal angles are level with the skids, because they sit slightly above the board the same as the 'humps' on the skid strips, so cargo doesn't slide on the wood .... from any original wood I've seen it always has been 3/4" - and I'd expect MarK to be selling 7/8" bed wood rabbeted for the edge angle if that's what was original [their oak is actually 25/32", not sure about the pine]
Bill | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Since I enjoy working with wood, I decided to make my own. Sorta got the idea from the previous thread. I have a hunk of oak that is just shy of 2" thick and I know the blocks are 2 1/4". Will it work if I put on a thicker pad? What should the overall height be and are the drilled holes dead center? Steve | | |
