| | | Forums66 Topics128,066 Posts1,055,871 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | front wheel hub,bearings,and seal. all the books and manuals show a wheel seal for my 1941 1-1/2 ton gmc. but I have no seal. from the inner bearing I have a spacer ring fits tight to the axle about .125th thick same hight as the bearing with a bevel inside. then a tin spacer that fit the outer hub but has a gap not tight to the axle. about .040th thick and the outside edge has a small lip. than one more tin like dust cover ring fits tight to the axle and is round enough to fit over the hub with a lip. I see no seal.... please help
I like fixing stuff.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | It should have a seal and a dust cover. If there is no seal, it could be that the last person who had the hub off couldn't find one and just assembled it without one. Do you have it dissembled. An inner bearing no. would help identify it. | | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | Hi katrina, You did not mention if you pulled just one wheel and hub or both. If only one, pull the other side and perhaps the parts you are looking for may be there for a positive ID-assembly? Do you need an exploded view of the front hub? If so, please let me know your truck model identification found on the following link: http://i391.photobucket.com/albums/oo352/46Canopy/GMCDataPlates-1.jpgI may have a good exploded view, and part numbers of what it is that you are missing. Hope this helps, Dale | | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | all set thanks guys ... bearing dust cover installed backwards was all bent up. got a new one replaced it and the other cover shield and bearing all line up nice. its always a treat to work on something that was done wrong and no maunal with the up grades on this truck can be found. so its yell for help and lots of internet looking for how too...
