| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 29 Apprentice | | Apprentice Joined: Feb 2005 Posts: 29 | After hearing a rattle inside the passenger door a few weeks ago (almost as if a big bolt was knocking around loose in the bottom), the passenger side door will now open only about twelve inches and then stop. It closes just fine, and it's not pinching on the inside edge when it opens.
I did a search on the site, and couldn't find anything to get me started. Before I start messing with hinges and such, does anyone have an idea about what may be happening?
Thanks in advance for any advice!
--John
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | sounds like maybe a bolt came loose from one of the hinges on the door side, might start by trying to get a peak at them
Bill | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Another possibility would be the "check" spring, they do break and a piece is jambed between the hinge and hinge pocketd? I'd stick a small magnet into the pocket and fish around or high pressure air. | | | | | Joined: Feb 2005 Posts: 29 Apprentice | | Apprentice Joined: Feb 2005 Posts: 29 | Squeeze & Yakima: Thanks for the tips!
I was a cruise-in last night, and another Stovebolter mentioned the check spring. The idea regarding the magnet is a good one --I'm going to go the parts store this weekend and get one of those magnets on an extension rod and see what comes up.
--John
