5 members (Gib70, greenie-reddy, Hotrod Lincoln, fonz8261, cmayna), 67 guests, and 4 robots.
Topics128,079
Posts1,056,300
Members48,441
Hello All, has anyone come across any direct replacement wheel cylinders for the 1949 style wheel cylinders? I was thinking 60's or 70's chevy ford or dodge with the correct 1 3/16 and 1 1/4 bore. Thanks in advance, Dave
Hi, Dave , Check Chevs of the 40's for parts. If you have the stock brakes they are the Huck style with two adjusters on the cylinders, they were last used in 1952. They are more difficult to set up. Think about changing to the Bendix type.( 1953 and later)
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
Riding in the Passing Lane
The half ton trucks used the Bendix brakes from 51 up. I agree it is a good swap to change over from the Huck brakes. If you keep the Huck brakes you will have to use the same type wheel cyls.
1972 Chevy c10 Cheyenne Super
That info applies to medium duty (3/4 ton) and larger trucks only. 1/2 tons switched to Bendix earlier as Wrenchbender pointed out. cervoned doesn't mention what size his truck is though.
Steve
'49 3800
'52 3600
'57 3100
he mentions its a 1/2 ton in the title.
Okay...missed that one!
Steve
'49 3800
'52 3600
'57 3100
Hi, guys,sorry about the wrong years. I was sampling my home brew last night.You know,if this bottle is good try the next and the next an,,,,,,,
You can still by new Raybestos wheel cylinders for the Huck-style from most NAPA FLAPS. I bought 4 last year. BTW different units front and rear. WC3396 and WC3406 (forget which is which!)
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Your numbers must be the Raybestos numbers,
the NAPA stock numbers for Huck wheel cylinders are:
UP-3604 $36.49
UP-3396 $73.99
Jim Carter pricing is better.
ME-322 $55.00 front or rear
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Raybestos indeed. Right off the boxes in my shop.
FLAPS price up here are about $50 each!!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
