3 members (Deegs53, tclederman, 1 invisible),
268
Mod | | | Forums66 Topics128,078 Posts1,056,054 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 2 New Guy | | New Guy Joined: Feb 2010 Posts: 2 | I recently purchased a new steering wheel for my truck as the old one is pretty worn. In my haste and without measuring or test fitting I bought a wheel off of a '55 Buick special. Once I had the wheel off of my truck I noticed a few diffrences. The splines on the column are too small for the Buick wheel. It has 2 posts coming off of the back (I am guessing to cancel turn signals) and no place to put the plastic GMC signal cancelation device on the back. Before I started hacking away at a really nice wheel I wanted to get some opinions. Is there any way to make this work? Thanks! | | | | | Joined: Apr 2010 Posts: 13 New Guy | | New Guy Joined: Apr 2010 Posts: 13 | I wouldn't bother, just resell it and find the correct wheel.
Is there anywhere that redoes these old wheels? Mine is cracked but otherwise good.
1965 GMC 910 Short Fleet 250/4-speed
| | | | | Joined: Feb 2010 Posts: 2 New Guy | | New Guy Joined: Feb 2010 Posts: 2 | I was going to try the bondo or epoxy method on my old one. Most of these wheels are made up of layers of paint. I think with some sanding, 3-4 thin layers of paint and 3-4 layers of clear (wet sanding in between) it would look nice.
Figured out I way over paid for that Buick wheel ($100). I guess it will make nice wall art:)
| | | | | Joined: Apr 2010 Posts: 13 New Guy | | New Guy Joined: Apr 2010 Posts: 13 | That sounds like a plan. I seem to recall seeing something about restoring these wheels using bondo like you mentioned.
As for the Buick wheel, if it's in good shape I would through it on ebay, if it sells great, if it doesn't then hang it on the wall.
