1 members (Nick in Manitou), 70 guests, and 3 robots.
Topics128,026
Posts1,055,408
Members48,422
#637328 04/13/2010 4:30 PM
How do I reset this without disconecting the battery.
Tommy
59 apache 1/2t
261 short stepside
Try autozone. They should be able to read the code and reset it - for free
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
the answer should be in the owner manual. Is it the 3000 mile oil change reminder or do you have a problem with the vehicle? You should know that answer before you just turn it off.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Z
Z Offline
like Green_98 said go to any auto parts store, autozone, advance, o'riely's, where ever, they'll read the code and delete it for free.
2000 Nissan Frontier, 3.3L (sold)
2006 Chevy Cobalt SS, 2.4L
1952 Chevy 1/2 pickup, 235 c.i. I6
when life speeds up, downshift
I know how to do the oil reset. This is the gas cap wasn't tight and the light came on called dealer they said tighten the gas cap, did that and the light went out. Now couple weeks later it's back on and the cap is tight, I assume it's still in the computer and just came back on. So I want to clear it, Used to be you disconnect batt for a few minutes and it would reset.Don't know if these newer trucks are the same.
Tommy
59 apache 1/2t
261 short stepside
if it came back, its not the evap system. have it checked.
if you like to do your own work, pick up software and cables from http://www.obd-2.com/
It could be the evap system, if the gasket on the cap is bad. I've seen that a few times. Replace the cap, problem solved. Not saying it is necessarily the case here, but it would be worth checking the cap for a bad gasket.
Bill Burmeister
