| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | How do I reset this without disconecting the battery.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Try autozone. They should be able to read the code and reset it - for free
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | the answer should be in the owner manual. Is it the 3000 mile oil change reminder or do you have a problem with the vehicle? You should know that answer before you just turn it off. | | | | | Joined: Sep 2009 Posts: 69 New Guy | | New Guy Joined: Sep 2009 Posts: 69 | like Green_98 said go to any auto parts store, autozone, advance, o'riely's, where ever, they'll read the code and delete it for free.
2000 Nissan Frontier, 3.3L (sold) 2006 Chevy Cobalt SS, 2.4L 1952 Chevy 1/2 pickup, 235 c.i. I6 when life speeds up, downshift
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I know how to do the oil reset. This is the gas cap wasn't tight and the light came on called dealer they said tighten the gas cap, did that and the light went out. Now couple weeks later it's back on and the cap is tight, I assume it's still in the computer and just came back on. So I want to clear it, Used to be you disconnect batt for a few minutes and it would reset.Don't know if these newer trucks are the same.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | if it came back, its not the evap system. have it checked. if you like to do your own work, pick up software and cables from http://www.obd-2.com/
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | if it came back, its not the evap system. have it checked. It could be the evap system, if the gasket on the cap is bad. I've seen that a few times. Replace the cap, problem solved. Not saying it is necessarily the case here, but it would be worth checking the cap for a bad gasket.
Bill Burmeister | | |
