0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 61 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 61 | O.K. so I have a 64 C20 and I am looking at the parking brake. I have the band that wraps around the transmission and I see nothing else. For what I see the band is for emergency stopping. How do you use the brake if you are on an incline, parked etc, etc.. I may be wrong on this since this truck is new (first truck) and I am not familar if all things. I do have the repair manual!
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | any parking brake can be used as an "emergency" brake [misnomer], but that's a "misuse", and hopefully never required .... the drive line parking brake on bigger trucks is used the same as any [the rear wheels can't turn if the driveshaft can't move], put it in 1st or R when parking for added safety
Bill | | | | | Joined: Mar 2010 Posts: 61 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 61 | Thank you I for some reason thought that the parking brake was for emergency purposes. I was looking for some kind of cable that when to the drums but could not find them. So now I understand the C20 system for the parking brake. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i actually like the propeller shaft parking brake on the 3/4 and bigger trucks. pull back and it holds, squeeze handle and foward and it's off. it's a little easier to get to than the under the dash one i think. | | | | | Joined: Apr 2010 Posts: 23 Apprentice | | Apprentice Joined: Apr 2010 Posts: 23 | The only parking brake that could be feasably used as an emergency brake I have ever seen was a transmission (output shaft) mounted hydraulic disc parking brake on a 40s hotrod. One of the trickest looking things I've ever seen. The owner told me he could bring the rig to a smooth stop using nothing but the parking brake. It looked way cool spinning down there under the car while it was moving. Not a very good thing for rough roads I would imagine though. | | |
