2 members (Otto Skorzeny, BC59), 259 guests, and 1 robot.
Topics128,080
Posts1,056,060
Members48,433
#636998 04/12/2010 5:42 PM
I recently purchased a new steering wheel for my truck as the old one is pretty worn. In my haste and without measuring or test fitting I bought a wheel off of a '55 Buick special. Once I had the wheel off of my truck I noticed a few diffrences. The splines on the column are too small for the Buick wheel. It has 2 posts coming off of the back (I am guessing to cancel turn signals) and no place to put the plastic GMC signal cancelation device on the back. Before I started hacking away at a really nice wheel I wanted to get some opinions. Is there any way to make this work? Thanks!
I wouldn't bother, just resell it and find the correct wheel.
Is there anywhere that redoes these old wheels? Mine is cracked but otherwise good.
1965 GMC 910 Short Fleet 250/4-speed
I was going to try the bondo or epoxy method on my old one. Most of these wheels are made up of layers of paint. I think with some sanding, 3-4 thin layers of paint and 3-4 layers of clear (wet sanding in between) it would look nice.
Figured out I way over paid for that Buick wheel ($100). I guess it will make nice wall art:)
That sounds like a plan. I seem to recall seeing something about restoring these wheels using bondo like you mentioned.
As for the Buick wheel, if it's in good shape I would through it on ebay, if it sells great, if it doesn't then hang it on the wall.
