13 members (klhansen, Otto Skorzeny, Jims46, manymiles, MikeE, Southerntruck, joe apple, Hawkman, J Lucas, D B Cooper, Oldcaliforniakid, 2 invisible),
103
Mod | | | Forums66 Topics128,049 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Long story short, tried to fire up the rebuilt 216 for the first time this weekend and had no luck not even a sputter. I'm getting spark to the number one plug, and played with the timing still no luck. During the rebuild I replaced the points and condenser with an electronic system. Any suggestions on what to try next?
Thanks Charlie 1953 3100 1/2 ton
1953 5 Window 1994 Harley, Heritage Softail Classic 2006 Chevy Colarado I didn't say it was your fault, I said I was blaming you.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | are you getting fuel? fuel + air + spark = fire | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | I used a spay bottle to spray gas into the carb.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Take off the valve cover & turn the engine watching # 6 rocker arms. When the ex. valve is almost closed & the intake is just starting to open, stop & remove the dist cap. The rotor should be pointing at #1 wire. The points should be just opened or about to open. The ball in the flywheel should be viseable in the opening over the starter. If all that is lined up it should run. If not are your valves adj. too tight? Is your spark strong & blue? Pull the high tention coil wire out of the dist. hold it near a ground & crank it. It should get good sparks as the engine rotates. Check these & let us know. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 9 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 9 | Do as instructed above, I was in the same situation. Is it turning over smooth? I had to put some oil down each cly.as mine had sat for a while since rebuild. Turned over with plugs out to lube the walls, put plugs in, gave it a snort of propane from a small propane bottle, six pumps on the gas pedal cranked over about three times and she was running!! never so happy in my life. She smoked a bit but purs like a kitten. Good luck, Keith | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Propane? never heard of that trick, how is that done
| | | | | Joined: Apr 2005 Posts: 9 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 9 | I don't know that this method is approved, but seemed to do the trick for me. Take your little 2.5lb propane torch commenly used for soldering or heating something small. Stick the end of the torch (NOT LIT) into the carb open valve 3 - 5 seconds, remove, try starting engine. Better then spilling gas all over. Like I said, I don't know if this method is approved, as with any experimental drug, always keep a fire extinguisher handy. As I mentioned it was 5 -6 yrs ago that I rebuilt my engine, which I bought from a guy that told me it hadn't run in about 15 yrs. When it started, I was in shock, what a good feeling!! I was even happier to find that I had a beer in the refrigerator! Good Luck, Keith | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | I use acetyline instead of Propane- - - -comes in really handy for finding vacuum leaks, too. Jerry
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Does it have compression? A quick check is easy and most likely if low to be tight valves or dry rings. Also check for a large vacuum leak. If very low compression and valves adjusted right a worst case would be the cam timed wrong.
Evan
| | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Thanks boys, I'm out of town until next weekend, I'll try everything and let you know.
Charllie
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hi Charlie. When I had my 235 rebuilt the mechanic came over a few times to get it running. No luck. He was hanging a gas can from the hood and said gravity would provide the truck with gas. I put a hose from the intake on the gas pump into the gas can. The truck started and I have had not problems since.
I did have my carburetor rebuilt by Mr. Carburetor in Dallas and had to set the timing. But other than that the truck runs good.
When you get it running come back and help me get the OD working.
Best of luck
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Hey Dennis, Thanks for the info, I'm looking forward to helping you with the OD, if I could just find the time.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | nice red truck, what is written on your black cap that you are wearing in your photo with your hand on the air breather in your photo album
have you ever made it to the El-Reno small town event first week of June......some of us Tx folks meet up with you Okies there, wife and I are planning on being there in June.. would be nice to see you and your truck there...
let us know when you get your truck running, looks like the suggestions made should do it...
Fred
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | I've been thinking (trouble I know) How much fuel should one add to the carb before and during trying to start the engine? Do I need to plug the wiper motor vacuum line or any other vacuum lines. Once the engine is started how is the engine timed with no marking on the engine to work with.
Can't wait to get back home on Friday and try starting it again.
Charlie
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Looks like it's all been addressed above. Good to see another OKIE on the site. If you can't get her going PM me @ [email protected] and I can try to arrange a time to come give you a hand.
| | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Thanks for the offer, the truck is located in Denision TX, I drive down every other weekend to work on it. I just moved to Oklahoma City and still looking for a place to store it.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Charlie. You said you get spark to the number one plug. I have run a braded ground line from my engine to the frame. I am a ground freak since bad grounds continuously give me trouble. Are you sure the distributor is right - not 180 degrees off? You can check this by pulling the #1 plug then turning the engine until you feel the compression - check the rotor direction under the distributor cap. Oh. Make sure you have the plug wires in the right order.
As for fuel in the carburetor. I will shoot a little starting fluid in my carburetor when mine is hard to start. I do not put gas in it.
And I would plug the vacuum wiper end of the plug in the manifold.
I hope this helps. Let us know
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Recheck the plug and point gaps. If the gap is wrong, it might not fire under compression. | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | She's alive, I followed WrenchedBender procedures and noticed that I was 180 off on the distrip rotated it to the correct location and she started right up. Thanks guys. I was jumping around like a kid in a candy store. LOL Next question will the fuel pump, pump gas out of a gas can? The fuel line is below the pump.
Charlie
