1 members (1 invisible), 46 guests, and 2 robots.
Topics128,043
Posts1,055,610
#636801 04/12/2010 1:00 AM
Hello, got a buddy with a '50 3100 that he's running a 400 in it with S10 master ,booster and prop. valve. He has brake pedal when the truck isn't running but as soon as it's started, the pedal drops to the floor. Any suggestions? Still air in the system possibly?Thanks, Brian
briank #636831 04/12/2010 3:43 AM
sounds like a booster problem but I'm not an expert.
Achipmunk #636863 04/12/2010 5:18 AM
3B Offline
Hy briank, your header says "no brakes", and you say the pedal drops to the floor when you start the engine. Can you move the truck with the engine running, or are the brakes locked up when the engine is running?
3B #636884 04/12/2010 11:22 AM
I'll have to ask him to make sure but I do not believe they are locked and it will roll.
briank #636954 04/12/2010 3:27 PM
3B Offline
Hy briank, it is normal for the brake pedal to go closer to the floor when the engine is started, it is one of the checks we perform to check the booster. Are the brakes adjusted up properly?
