| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 94 | The old 216 in my 46 2 ton is starting to get pretty tired. I like using the old 46 for pulling things around the yard since it is geared low. I was just wandering what would be the easiest engine swap that would get me quite a bit more horsepower?? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jordi55, the 54 235 or 261 would be the easiest, but they are also the rarest of the 235 261 engines. You can use the 55 and up engines, and order the special short shaft water pump, or use the plate adapter and use the older water pump. You'll have to use the flywheel, bellhousing, clutch etc. from your 216, to make it match up to your truck. Actually either swap if fairly easy, good luck. | | | | | Joined: Apr 2010 Posts: 7 New Guy | | New Guy Joined: Apr 2010 Posts: 7 | a 250 will be fine and its a good motor just but a shorter water pump and u can u the fan or put a eletric fan thats what i have on my fleetline | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i just got finished putting a 59-235 in my 51 dump all by myself. its real easy with lots more power than i had before with the splash engine. i was asked along the way why i wasnt putting something bigger in and i said simplicity. all the changes were done on the engine not the truck ie.(motor mount location, steering, suspension, radiator.) and it has all the power im going to need. it was right out and right back in. | | | | | Joined: Mar 2009 Posts: 93 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 93 | The newer inlines (1955+) will fit with out the short water pump. You'll just have to move the radiator forward. All it takes is putting it on the other side of the core support and moding sheet metal. Someone did it to mine and After I finish cleaning up the badly done hick-job it don't look half bad. Mine has a 1959 261. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i used the water pump adaptor plate and used the original style pump and didnt have to move anything. the adapter seals up the hole in the later blocks and the original pump bolts to the plate. i had concerns of where the location of the fan would be since i have a radiator shroud on mine. no changes were needed and no contact between the fan and the shroud. | | |
