2 members (carbking, RLB),
157
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | I am trying to remove the front brake drum on a truck that has been sitting for a long time. the drum turns freely so I don't think the brake pad is too tight. Is there a trick to get stuborn drums off? | | | | | Joined: Jan 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 126 | I'm sure you have but just in case....You have removed the wheel nut that holds the hub on, right? | | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | Of course the wheel is off...I can move the drum outward just a little bit, Maybe the brake shoes are catching it and kind of holding it in place? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes the brake shoes are likely catching on the wear lip of the drum, use the adjuster to relax them a bunch and it'll likely come apart
Bill | | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | If that doesn't help would it be possible to do it by removing the bearing and putting the tire back on and pull the assembly off as a whole? | | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | " From brake drum removal?" Man I must be tired because what I meant was FRONT brake drum removal? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If it's catching on the rust ridge, it probably won't work. Turn the adjuster all the way back like squeeze said, it should come off. There could also be some rust interference on the hub itself. Give it a shot of penetrant oil, like B'Laster or Kroil, and lightly rap the drum at the outside edge with a hammer, preferrably brass. That will free it up, and will also "walk" the drum over the shoes. You migth also lightly pry the drum once you get enough space to get a large screwdriver or small prybar in between the drum and backing plate. Key word is "Lightly", just enough force that when you rap it with the hammer, the drum moves off.
Bill Burmeister | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I don't understand why you are not taking the bearing nut off & pulling the hub off too. You need to service the bearings also. If it doesn't come off you need to back up the adjustment, like Squeeze say's. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 126 | I meant what wrenchbender says. On the front drums, they are sometimes riveted to the hub. (not the wheel, the hub)You have to pull the bearings and hub off the axle to get the drum off, its like the hub and drum are one unit.
For what its worth, if you need a new drum, you don't have to re-rivet it to the hub when you put it back together. | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | The first time I serviced the front brakes (drums riveted to hubs) I pulled the hubs and all. After grinding the heads off and pressing the rivets out, I replaced the bearings & seals and rebuilt the brakes. I think it'd be too hard to remove the rivets with the hubs on the truck.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | 65 Chevy Guy,
I just did this tonight on my '65 C10. Squeeze and Longbox55 were right on the money! There is a slot on the face of the drum, turn the drum until you see a star wheel through this slot...that's your adjuster to relax the pads. Turn that star with a large straight blade screwdriver far enough and hopefully your drum will slip right off like mine did. Good luck!
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Jan 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 126 | Mine had the same slot on the front of the drum. Not sure why Chevy put it there instead of in the backer plate like most rigs....I had to replace 2 drums, they were too far gone to turn, and I couldn't find any anywhere with a slot in them. Wound up having to drill and cut an adjuster slot in the backing plate myself. | | |
