0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63653 07/30/2006 3:47 PM | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Hi All, Just a quick question for you 216 Gurus. I have recently reinstalled a 216 in my daily driver and I have oil leaks around the #1 and #6 spark plug holes. The side lifter cover goes up and around the spark plug holes and I was wondering if there was an O-ring or gasket that is giving me troubles. I hope that is all it is. I had 235's in my trucks and this 216 is new to me. Thanks! Ralph | | |
#63654 07/30/2006 4:29 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | There should be six cork gaskets, one per spark plug hole. Trouble with that design, as you know by now, zillions of places to leak oil. I believe Tom Langdon still makes an aluminum cover for those.
Also, make sure rocker cover is not warped, most of these get over tightened. | | |
#63655 07/30/2006 9:50 PM | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Thanks for the reply JiMerit. You comfirmed what I was thinking. Time to go get my hands dirty. Ralph | | |
