| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Does anyone know where I can get my hands on a Zenith updraft cab for my 52 GMC COE? The Zenith part number is 11513. Or does anyone know of a replacement carb that will work for the 248 engine? Any input is greatly appreciated.
Glory Bound...
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Ive found several NOS units on ebay in the past that worked great as a replacement on my 248. Ill try and dig up the carb number in the near future.
Jeff | | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | Rautu, I've got one off a 2 ton Chev COE, If it's the number your looking for I'll PM you Friday.
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Chevrolet COE's used the Carter updraft carburetors. If off a '53,or earlier COE, mounts facing backwards, on the Chevy's | | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | I should have waited for your response Spanky, your spot on. It's a Carter alright.....gosh Spanky your always right.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Old tractors used zenith updrafts.
| | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Thanks everyone for your input, but I now have a bigger problem, my money maker threw a rod. Money Maker being a 52 Chevy ton and a half grain truck with a hydrualic lift. It had the 216 Babbit, but I want to replace it with a 235 or a 260, any infor on that is also greatly appreciated. Like, will it go right in without any major changes
Raul
Glory Bound...
