| | | Forums66 Topics128,041 Posts1,055,593 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 10 New Guy | | New Guy Joined: Dec 2009 Posts: 10 | Were there kick panels in cabs during this era? I saw a fixed up COE hot rod with speakers down in front of the doors. Realizing that location, I went to my truck to realize that there weren't kick panels there and that I can see the door hinges with the doors closed. Were there kcik panels or what that a custom thing going on in that COE? Brandon 1988 4Runner: SR5 ~ 3.0 ~ 5-Speed ~ No Sway Bar ~ 3-Point Rear Seatbelts ~ KC Daylighters ~ EGR By-Pass 1946 Stovebolt: Rebuilt 216 ~ 6V ~ All Stock Extras: Stuff for my signature that just wouldn't fit.
| | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | Yes they did have "kick Panels" they where made of hard cardboard like the headliner. | | | | | Joined: Nov 2008 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 101 | If you look on Chev's of the 40's or Jim Carter's you'll see pictures of the kick panels. They are basically shaped like the State of Nevada - LOL but true. I recently bought a two piece headliner for my '46 and it is made of the same cardboard the kick panels are made of...I'm not impressed. I plan to cover the headliner pieces with black Naughahyde. Since the kick panels are flat, I plan on making my own from 1/8" or 1/4" plywood and covering them the same as the headliner cardboard. I will probably mount speakers in them too. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | the panels in my 40 were shot. for a temp fix i made them out of a cardboard box and painted them the same as the cab. since then i got a pair of abs panels and a pair of abs speaker pods from "rod doors" painted the panels and the pods same as cab color. now i have a good sound system that is neat, clean and almost hidden. i mounted a removable cd player that is wired for the ashton. with the addition of an ipod no more skipping plus the music drowns out the sound of the engine when at cruising speed. | | |
