3 members (TUTS 59, Jon G, Joe H),
97
Mod | | | Forums66 Topics128,026 Posts1,055,402 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63564 07/28/2006 1:15 AM | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Can someone tell me the torque specs for a 1942 Chevy 235 engine? Thanks!!!! [email protected] | | |
#63565 07/28/2006 2:17 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You'll need one of these anyway, now's as good a time as any. It'll answer a lot of your questions.
#63566 07/28/2006 4:27 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
#63567 07/28/2006 12:52 PM | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | I have the Chevy 1942 manual but I need the torque specs for rod bolts, main bearing bolts, etc. If it is in the 1942 manual I must have miss it, what page is it on. Thanks!!! | | |
#63568 07/30/2006 5:28 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Main bolts are 100-110 lbs. ft.
rod bolts are 55-60 lbs. ft.
any other question just ask
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#63569 07/30/2006 12:36 PM | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Oly, Thanks!!!! for your help and to all that replied to my posting. If someone finds a web site with all the torque specs on the internet please let me know. Thanks!!! again to all, will let you know if it runs. [email protected] | | |
#63570 07/30/2006 4:56 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Marvin, I don't know what all you're needing- but, the head bolt torque is 75-80 lbs. ft. If you need the sequence let me know. Also If you need the clearances, I can give you those.
#63571 07/30/2006 5:04 PM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | My old GM manual states 40-50 ft lbs ,oiled threads on the rod nuts. | | |
#63572 07/30/2006 5:21 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | I am assuming he is talking about a 42 216 (not 235) and all rod bolt torques for 35-48 for 216 are 55-60 lbs. ft.. The rod bolt torque for 49-** are 40-50 lbs. ft..
This info is from my 1951 Motors Auto Repair Manual.
#63573 07/31/2006 11:16 AM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | One of these books is a miss print,I have several other non GM manuals stating 40-50 on the rod bolts for a 1942 engine,and all the years beyond that including the 235-261 engines. GM parts manual lists the same part number for the rod bolt, all 6 cylinder engines 38-53.60 ft lbs of torque on a 3/8 bolt is extremely high.ARP,who manufactures rod bolts far superior to any original GM bolt,recomends a maximum torque of 50 ft lbs on a 3/8 fine thread bolt. | | |
#63574 08/04/2006 11:17 PM | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | The weak link in the 235 lower end is the stock rod bolts. Swaping in big block chevy (454)rod bolts will solve this problem. They are however not cheap.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
