4 members (68ironhead, Hanks custodian, Gray_Ghost, Ponchogl), 51 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
#63564 07/28/2006 1:15 AM
Can someone tell me the torque specs for a 1942 Chevy 235 engine? Thanks!!!! [email protected]
Ex Hall Monitor
Ex Hall Monitor
You'll need one of these anyway, now's as good a time as any. It'll answer a lot of your questions.
I have the Chevy 1942 manual but I need the torque specs for rod bolts, main bearing bolts, etc. If it is in the 1942 manual I must have miss it, what page is it on. Thanks!!!
Oly Offline
Main bolts are 100-110 lbs. ft.
rod bolts are 55-60 lbs. ft.
any other question just ask
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
Oly,
Thanks!!!! for your help and to all that replied to my posting. If someone finds a web site with all the torque specs on the internet please let me know. Thanks!!! again to all, will let you know if it runs. [email protected]
Oly Offline
Marvin, I don't know what all you're needing- but, the head bolt torque is 75-80 lbs. ft. If you need the sequence let me know. Also If you need the clearances, I can give you those.
Oly in Oregon
Rest in Peace
1953 Willys CJ3B
knuckle head
knuckle head
My old GM manual states 40-50 ft lbs ,oiled threads on the rod nuts.
Oly Offline
I am assuming he is talking about a 42 216 (not 235) and all rod bolt torques for 35-48 for 216 are 55-60 lbs. ft.. The rod bolt torque for 49-** are 40-50 lbs. ft..
This info is from my 1951 Motors Auto Repair Manual.
Oly in Oregon
Rest in Peace
1953 Willys CJ3B
knuckle head
knuckle head
One of these books is a miss print,I have several other non GM manuals stating 40-50 on the rod bolts for a 1942 engine,and all the years beyond that including the 235-261 engines. GM parts manual lists the same part number for the rod bolt, all 6 cylinder engines 38-53.60 ft lbs of torque on a 3/8 bolt is extremely high.ARP,who manufactures rod bolts far superior to any original GM bolt,recomends a maximum torque of 50 ft lbs on a 3/8 fine thread bolt.
The weak link in the 235 lower end is the stock rod bolts. Swaping in big block chevy (454)rod bolts will solve this problem. They are however not cheap.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
