1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 10 New Guy | | New Guy Joined: Dec 2009 Posts: 10 | I've tried to attatch the cable to the trannie many times. Unfortunatly, the only successful part of this is the screwing on of the cable. I would sware that something right inside the trannie that sends the spin through the cable is broken. The tip of the cable is find, but I believe the femal end in the trannie is worn. Is this common and is there a way to repair it?
Thanks. Brandon 1988 4Runner: SR5 ~ 3.0 ~ 5-Speed ~ No Sway Bar ~ 3-Point Rear Seatbelts ~ KC Daylighters ~ EGR By-Pass 1946 Stovebolt: Rebuilt 216 ~ 6V ~ All Stock Extras: Stuff for my signature that just wouldn't fit.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | hook it up, run it to the cab and go for a short distance holding the end of it. if its turning then its working | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | be sure the drive cable inside the case extends out enough to engage the tranny drive. Insert the drive cable only and try to turn it, if it turns freely there's a problem. If it doesn't turn then the drive cable is probably too short, not engaging the tranny drive.
Ed
