| | | Forums66 Topics128,078 Posts1,056,046 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | For the most part my truck is in good shape but I do need to replace one lower cowel outer skin and one rocker. I am having a hard time finding repair panels.Boy some of the parts sites are a hard to navigate. Are these panels avalible or will I have to make my own? Not really interested in fiberglass.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | That page is down,I will try it again later, Thanks Tiny.
| | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | You are in the same boat as I am. I had one lower cab corner that had been smacked and had at least 3\4 inch of bondo (original repair) after spending hours of stripping, treating the metal, and reforming with body hammers and dollies, I finally went with one fiberglass sheet over the top and beefed up the back. It will still hold a small magnet to the surface (if that is important) but unless I had access to a replacement corner or making a panel myself with days of tedious hammering and dolly work I doubt that I could of got it that close. The metal is stable and until a re-pop comes along it will stay that way. | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I am suprised no body makes these parts. There is a market.I just need the outer skin, guess Ill have to make it myself.
