7 members (tclederman, Gdads51, 1955 1 Series, moparguy, Gray_Ghost, Otto Skorzeny, 1 invisible),
75
10
Mod | | | Forums66 Topics128,078 Posts1,056,027 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | I have searched and found pictures of cab removal. I saw people removing the cab by putting 2*4 from one top door opening to other and putting the engine crane lift from bottom. I was always worried about egging out the cab because you are lifting the whole cab by roof or hanging on A pillars and will the bottom sag. I have a forklift, I could stick the forks through the door entrace and lift the cab. I dont have doors and cab is bare bone except for windshield. Will I egg out the cab on not is my major worry. Lots of work has gone into floor pans
Thanks for reading and answering
Ganesh | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no you won't bother it, the pillars and door openings are actually multiple layers .... example of how tough the roof structure is  also because my forks aren't lomg enough to go all the way thru, I've lifted TF cabs w/ it by putting some 2x4 front to back, under the dash to the ledge below the rear window Bill | | | | | Joined: Jul 2008 Posts: 28 New Guy | | New Guy Joined: Jul 2008 Posts: 28 | My 16 year old son and I lifted ours up off the frame and placed it on a rolling dolly in our shop. Its not that heavy and not that hard to remove once you have it all dis-connected. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | It won't egg and they are very stiff. You can use a lift or straps or carry it. You will do more damage with the forklift that would be a last resort to me. | | |
