3 members (delky, Hanks custodian, Rich'sToys), 127 guests, and 3 robots.
Topics128,149
Posts1,056,817
Members48,454
This is similar to the 38 tag question earlier. Where or how exactly does the ID tag go on a 46 Chevy 1/2 ton truck? It appears to go on the passenger side cowl around the corner from the firewall in front of the cowl to hood seal but does it go horizontal or vertical and facing forward?? There are multiple holes in the area and none seem to fit correctly. Did they use screws or rivets in opposite corners only or in all four corners? Thanks!!!!
54 Chevy 5 window - 46 Chevy 1/2 ton
There were two plates on my cowl, both unreadable, so I picked up a repro and stamped in my vin. The factory plate had the body number which told the story, which plant, etc etc. Also the larger of the two plates I've mounted verticle, just because it fits the holes. The screws are tiny 'clutch head', and I've only seen these screws on the id plates. I can shoot a photo if you want, but you may get a responce from others with more correct info on what the originals looked like. Best of luck
1946 1/2-Ton Chevy
This is where mine is attached (also a '46). Can't say for 100% its in the factory location, but I believe it is. Mine is also attached with clutch head screws.VIN attach
1946 Chevrolet 1/2-ton
More pix on Photobucket
